Exhaust leak
  • OGCrunches
  • OGCrunches's Avatar Topic Author
Exhaust leak
10 Dec 2020 19:35
#839777
Ive got a 1975 KZ 400D.
So my exhaust seems to be the 2 piece design and is leaking at the block and where the mufflers slips on. Ive got new gaskets on the way as well as red permatex for the block. But is there supposed to be a clamp in the center section?
  • TexasKZ
  • TexasKZ's Avatar
Re: Exhaust leak
10 Dec 2020 19:47
#839778
  • OGCrunches
Re: Exhaust leak
11 Dec 2020 08:15
#839794
This is what i got. The shapes look slightly different than the stock photo.
  • TexasKZ
  • TexasKZ's Avatar
Re: Exhaust leak
11 Dec 2020 14:51
#839805
When you say block, are you planning to put sealer between the head pipes and the cylinder head?
If so, I hope you can be persuaded otherwise. Nothing is needed there except a new crush washer.
  • OGCrunches
Re: Exhaust leak
11 Dec 2020 18:59
#839839
I think i may just use it to help seal the middle connection. It was just slid together. Do i may use some sealant and a clamp
  • TexasKZ
  • TexasKZ's Avatar
Re: Exhaust leak
12 Dec 2020 08:52
#839857
Looks like you have a pretty prodigious oil leak, too.
  • OGCrunches
Re: Exhaust leak
13 Dec 2020 13:53
#839961
Not oil. I jad just sptayed the echaust bolts with pb blaster!
  • OGCrunches
Re: Exhaust leak
13 Dec 2020 13:54
#839962
And english has failed me once again haha.
  • TexasKZ
  • TexasKZ's Avatar
Re: Exhaust leak
13 Dec 2020 15:47
#839974
Ah, a prodigious penetrating oil leak :silly:
