KZ750 exhaust
  • Claude.
  • Claude.'s Avatar Topic Author
KZ750 exhaust
08 Dec 2020 05:40
#839556
I am about to get a 1984 KZ750L4 project bike for restoration. The bike currently has a Yoshimura 4-1 but I prefer an OEM exhaust.
I found an OEM exhaust off a 1977/1979 KZ750. Anyone knows if it will fit on a 1984?
Once again, thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
  • Nessism
  • Nessism's Avatar
Re: KZ750 exhaust
08 Dec 2020 06:59
#839559
1977/1979 KZ750's are TWIN cylinder bikes so the answer is NO.
If you have made an error and meant to say 1977/1979 KZ650 then the answer is maybe. The exhaust will bolt up to the head and clear the oil pan no problem, but it's unlikely to align with the footpeg brackets in the back, although you may be able to make it fit with some modifications.
The following user(s) said Thank You: Claude.
  • Claude.
Re: KZ750 exhaust
08 Dec 2020 18:40 - 08 Dec 2020 18:41
#839628
You're right, of course ; There’s so much I have to learn...
The 77-79 quote comes from the seller. I asked him after I read your post and he is unsure. The exhaust is for a 4 cylinder engine. He is selling parts from 650 and 750. The exhaust could be from a 650 but aren’t they with a reverse cone tip? The unit for sale has kind of trumpet shaped last section. Could you tell if I post the picture?
Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 08 Dec 2020 18:41 by Claude..
  • martin_csr
  • martin_csr's Avatar
Re: KZ750 exhaust
09 Dec 2020 08:31 - 09 Dec 2020 08:39
#839653
Pics always help. Some (most?) KZs have model info stamped into the mufflers.
Also, I don't know if it matters, but the 750L mufflers are clamped in place instead of being welded & I don't know if a welded-on-muffler system would be problematic, such as for doing a tire change or something. Cmsnl.com is the only place I know of that has diagrams for some Euro models.
Last edit: 09 Dec 2020 08:39 by martin_csr.
  • Claude.
Re: KZ750 exhaust
10 Dec 2020 05:54
#839730
Here's the exhaust I found locally. Just by the look, can you tell which model it comes from?
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • martin_csr
Re: KZ750 exhaust
10 Dec 2020 07:18 - 10 Dec 2020 09:53
#839740
I don' know what that is. In the USA:
77-80 KZ650s had cone-end mufflers, not megaphones as shown in the pic. ... (pretty sure).
81-83 KZ650s had megaphone mufflers but the headers tips have flanges welded-on, not flared as shown in the pic.
From the 81 KZ650 FSM the Euro models had megaphone mufflers & I assume they also had the header flanges.
Also, I would assume any 81-on system would have some sort of identification stamped into it. either the model or a Sankei number or something.
Stock mufflers. The 750L mufflers have recesses in them that might be for the axle and/or center stand clearance.
see eBay item number: 264164046375. I have no idea how a non-stock system will fit.
ZN mufflers. If I had a 750L, I'd look into a ZN700/750 muffler system or at least the manifold assy.
Last edit: 10 Dec 2020 09:53 by martin_csr.
  • Claude.
Re: KZ750 exhaust
10 Dec 2020 07:45 - 10 Dec 2020 07:45
#839742
I just saw pics of a 1982 KZ750LTD that have megaphone mufflers but, as you said, there is a recess on the LH one for the centerstand.
I just asked the seller to send me a pictures of the stamped information. I'll be back with this info if I receive it.
Thanks a lot for your time!!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 10 Dec 2020 07:45 by Claude..
  • martin_csr
Re: KZ750 exhaust
10 Dec 2020 09:54 - 11 Dec 2020 06:11
#839744
The muffler covers don't look right for a 750-4 Ltd. and I can't tell if they're welded-on or clamped/bolted in place.
80s style mufflers have longer muffler covers (heat shields). and are removable on all KZs.
Also, if there isn't a crossover pipe, those could be aftermarket.
BlackWidowExhausts in the UK sells a Zephyr ss manifold that might fit.
Last edit: 11 Dec 2020 06:11 by martin_csr.
  • Ninja1195
  • Ninja1195's Avatar
Re: KZ750 exhaust
12 Dec 2020 16:03
#839873
Seller here!
A while ago I purchased misc items from a fellow who made a few KZ650 into (gasp!) cafe racers and had leftover parts.
Those mufflers in question have absolutely no stamps or markings making me think they are not OEM.
1978 KZ650 B2
  • Claude.
Re: KZ750 exhaust
12 Dec 2020 18:26
#839887
As you wrote, they are surely not OEM. I ignore which aftermarket exhaust manufacturers makes a 4-2. But there also still a million of things I ignore about KZ bikes...
If I was living physically closer to you, I would borrow the exhaust to test try it on my KZ750 but that’s not really possible... Thanks anyway for the info you provided!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
The following user(s) said Thank You: Ninja1195
  • Claude.
Re: KZ750 exhaust
15 Jan 2021 14:07 - 15 Jan 2021 14:09
#841744
I found a complete OEM exhaust off a 1978 650SR that seems to be in quite good condition; depending of the anwers to my question below, I could go back there next week to inpect it closely, I am posting a picture below coming from an old post from Martin_CSR.
Question is: WIll this exhaust fit on my 1984 KZ750L4? As I wrote in OP, I prefer the look of a 4-2 system to replace the current 4-1 Yoshimura of my 750.
I understand I could have to adapt the mufflers hanger bracket's holes but the system must fit on the engine.
Thanks!
NOTE: I think this exhaust looks kind of cool with the des ign of the front tubes!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 15 Jan 2021 14:09 by Claude..
  • missionkz
  • missionkz's Avatar
Re: KZ750 exhaust
15 Jan 2021 14:20
#841745
Here's what the 2 into 1 headers look like from my 1979 KZ750B >>>>
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
