05 KZ1000P Piston Rings Question 13008-5035 vs 13008-5056
- ken19
30 Nov 2020 11:11
Z1 Enterprises has some rings for about $30 dollars a set. They say they fit all J models. Made in Japan. Good Quality. They give equivalent Kawasaki P/N of 13008-5035. Partzilla states that number fits 81-86 models.
When I researched it the OEM says to use 13008-5056. Z1 says they probably superseded the number. Now I happen to believe Z1
I'm wondering if this might have to do with the "Smokey J" issue.
Expert opinions appreciated..... even non experts....
Re: 05 KZ1000P Piston Rings Question 13008-5035 vs 13008-5056
30 Nov 2020 14:33
In looking on Partzilla it seems that PN 13008-5035 was superseded by PN 13008-5056. Both the early and late J engines used the same PN 13001-1119 piston so using the later rings in an early engine should be okay as near as I can tell.
- ken19
30 Nov 2020 16:05
So their both basically the same part? The 5035 can be used on early or late models. Kind of confusing.
Thanks Nessism
Thanks Nessism
- ken19
26 Dec 2020 15:33
Purchased one set of rings (13008-5056) and 3 sets (13008-5035). Completely identical (to the eye) and all fit the same.
The only difference I saw besides the price was the packaging. The 5056 ($54) was a Kawasaki Package while the 5035 ($30) was NPC. Both made in Japan.
I suspect Kawasaki purchased them from NPC repackaged with the Kawasaki brand. JMO....
