Endless clutch repair.
  • Nathanb
  • Nathanb's Avatar Topic Author
28 Nov 2020 12:20
#839127
Clutch Basket moves about 1/2 both ways after replacing installing new plates. Does that mean I need to replace new clutch bearings? 1982 GPZ 550 h1
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: Endless clutch repair.
28 Nov 2020 12:24
#839128
1/2 turn? 1/2 inch? 1/2 mm?
Moving in and out, or rotating? Wobbling?
Please give us a bit more info or a video, please.
  • Nathanb
28 Nov 2020 16:07
#839136
The whole basket swings from side to side a half inch each way I'll send you a video with me wiggling it it doesn't wobble it doesn't go in and out it just goes side to side about a half inch each way
  • Nathanb
28 Nov 2020 16:09
#839137
Is that normal for it to swing side to side like that?
  • Nathanb
28 Nov 2020 16:24
#839138
I attached the video twice some reason it's not showing up. But it will move from side to side a half inch about it doesn't wobble it just it's tight in but it doesn't but it goes back and forth I wasn't sure if that was normal or not cuz I'm getting ready to tear it apart and change the clutch bearings.
The whole basket
