Starter Clutch Question
  • jleemiller99
  • jleemiller99's Avatar Topic Author
23 Nov 2020 18:05 - 23 Nov 2020 18:11
#838803
Hey guys! Another question for you. I’m finishing up my ‘82 KZ750 Four (knock on wood) with a new starter clutch assembly. Got everything out smoothly and without an issue, but I realized too little too late that I skipped a step. I used a clutch basket holding tool and an impact driver to remove the secondary shaft nuts on both sides, but I did not remove the alternator cover to hold the rotor in place to keep the crankshaft from turning while I was removing the nut on the engine sprocket side. The bike is in neutral of course and the primary chain is in the same position as it was when I tapped out the secondary shaft and the crankshaft appears to be locked in place anyways. Have I made a huge mistake here or should I be okay with a whole lot of luck? Also should I go ahead and hold the rotor upon reinstallation of the secondary shaft or will I be fine? I have my manual handy but it doesn’t go in depth on this. Thanks guys!
Last edit: 23 Nov 2020 18:11 by jleemiller99.
  • Cfoux85
  • Cfoux85's Avatar
  • 1982 Kawasaki kz 750e
Re: Starter Clutch Question
01 Sep 2021 18:56
#854703
I'm about to replace mine, I ordered my starter clutch and all so I'll be starting the work on the 9th. I'm going to try and remove it from the bottom but I have no idea what to do so any advise or info would be greatly appreciated. The screws on both left and right side covers are so tight that I end up having to tap them out. I haven't taken either side covers off yet so any suggestions on the easiest way to to do this job? Right now I have only removed the oil pan and that's basically it, where do I go from here? Any help would be greatly appreciated
  • azman857
  • azman857's Avatar
01 Sep 2021 20:59
#854711
After the clutch is out the oil pump needs to be removed.
You might want to read the thread about guy did about putting in the 6 speed trans from a KZ 550. He upgraded the starter clutch from a ZR 750. I think it was a ZR. Way better than the stock was new. It's a bolt in too. Other than the placement of shim/spacers used which are stock parts anyway. I put one in my project on his write-up. They are not that expensive too. Ebay is where I got mine. The shaft, oil pump and pressure relief valve are bolt in too.
The following user(s) said Thank You: Cfoux85
  • TexasKZ
  • TexasKZ's Avatar
01 Sep 2021 21:34
#854713
Cfoux85,
It really depends on which KZ you have. For example, the KZ1000 starter clutch is dramatically different from the KZ650. The removal and replacement procedures are completely different.
  • Cfoux85
  • Cfoux85's Avatar
01 Sep 2021 22:50
#854717
Oh ok well I have the 82 kz750e.
