z1r valve stem seals
  • david richard
  • david richard's Avatar Topic Author
21 Nov 2020 09:28
#838709
what is the best valve stem seals to replace either vitron or should i stay with oe ones thanks
  • Nessism
  • Nessism's Avatar
Re: z1r valve stem seals
21 Nov 2020 09:54 - 21 Nov 2020 10:01
#838712
I used Viton. A member here sells them for good prices.
Edit: found the member... www.kzrider.com/forum/profile/18962-dfigpz
Last edit: 21 Nov 2020 10:01 by Nessism.
The following user(s) said Thank You: david richard
