KZ1000J Engine numbers
  • philsg
  • philsg's Avatar Topic Author
10 Nov 2020 00:40
#838296
I have a KZ100J engine fitted in a KZ1000R frame.
The engine number is KZT00JE000094 - how do I trace the year in order to order spares.
The frame number is KZT00R005435 - believe the frame is 1981/1982
Cannot see any other number (eg VIN) if used as it it not a US model (it's in South Africa)
All help welcome.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: KZ1000J Engine numbers
10 Nov 2020 05:34 - 10 Nov 2020 05:39
#838301
The frame number is the vin. There should also be a white sticker next to the stamped number. The sticker has the date of manufacture and such. Somebody may have removed or painted over the sticker. You can find the model year based on the frame number on he back cover of the factory service manual.
www.kzrider.com/modules/ServiceManuals/G...R_Service_Manual.pdf
There is a website that lists the engine numbers, but I seem to be having a bit of a senior moment. Someone else with a better memory will be along shortly with that web address.
Last edit: 10 Nov 2020 05:39 by TexasKZ.
  • Warren3200gt
  • Warren3200gt's Avatar
10 Nov 2020 05:35 - 10 Nov 2020 05:39
#838302
www.zedder.com/msg1.htm bookmark for you TexasKZ
Year & Model '81 KZ1000-J1
Color(s) Luminous Ruby Red
VIN Range JKAKZCJ1vBA000001 - 007900
Engine No. Range KZTOOJE000001 - 019200
Year & Model '82 KZ1000-J2
Color(s) (1) Ebony (USA only)
(2) Galaxy Silver
VIN Range JKAKZCJ1vCA007901 - 017500
Engine No. Range KZTOOJE019201 -039300
Year & Model '83 KZ1000-J3 (Canada only)
Color(s) Ebony
VIN Range JKAKZCJ1vDA017501 -
Engine No. Range KZTOOJE039301 -
Year & Model '82 KZ1000-R1:Replica (USA only)
Color(s) Lime Green
VIN Range JKAKZCR1vCA000001 - 001100
Engine No. Range KZTOOJE031001 - 039300
Year & Model '83 KZ1000-R2:Replica
Color(s) Lime Green
VIN Range JKAKZCR1vDA001101 - ?
Engine No. Range KZTOOJE039301 - ?
Last edit: 10 Nov 2020 05:39 by Warren3200gt.
The following user(s) said Thank You: TexasKZ
  • TexasKZ
  • TexasKZ's Avatar
  • Away
10 Nov 2020 05:43
#838303
The engine could also be from an LTD (K), a CSR (M), or a police bike (P).
  • philsg
10 Nov 2020 06:24
#838304
Thanks for the info
Have found the bike & frame is a 1983 model KZ1000R (ELR).
From other replies it looks like the engine is from a 1981 KJZ1000J
Waiting for confirmation from Kawasaki South Africa.
