Clutch pushrod ball bearing installation.
  • loneagle
  • loneagle's Avatar Topic Author
28 Oct 2020 10:35
#837879
I own a 78 KZ1000. Does the ball bearing install from the left side along with the pushrod or from the clutch side behind the pusher? Is the diameter of the ball .375?
Thank you
'78 Kawasaki KZ 1000
'02 Harley FXDWG
'16 Harley Street Glide
  • martin_csr
  • martin_csr's Avatar
Re: Clutch pushrod ball bearing installation.
28 Oct 2020 12:20 - 28 Oct 2020 12:21
#837885
I haven't looked up the 1000A specifically, but every KZ clutch pushrod ball I've seen in the diagrams is listed as 3/8 (= 0.375).
Last edit: 28 Oct 2020 12:21 by martin_csr.
The following user(s) said Thank You: loneagle
28 Oct 2020 12:23
#837886
Pardon me if this appears to be a rude comment, but did you ever consider simply looking in the Kawasaki Service Manual? You might be surprised at how much information it contains. Ed
  • ghostdive
  • ghostdive's Avatar
28 Oct 2020 12:47
#837889
It goes in the clutch side behind the uhh...end part thing.
2001 ZX-6R
  • loneagle
28 Oct 2020 13:50 - 28 Oct 2020 13:52
#837892
Where in the factory service manual does it state the ball goes in on the clutch side?
I've seen some members say, the ball goes in before the pushrod. Also , it can fall out when the pushrod is removed. I've used the search function, but found conflicting information.
'02 Harley FXDWG
Last edit: 28 Oct 2020 13:52 by loneagle.
28 Oct 2020 14:22 - 28 Oct 2020 14:26
#837894
Loneagle wrote "Where in the factory service manual does it state the ball goes in on the clutch side?
Look at page 72. Ed
Attachment 00011.jpg not found
Last edit: 28 Oct 2020 14:26 by 650ed.
  • Zeerx
  • Zeerx's Avatar
28 Oct 2020 14:52
#837899
I bought an extra push rod and ground off the thickness of the ball on one end. Then I put a ball on each end. Seemed to make clutch use slightly easier. YMMV.
‘78 KZ750B, ‘12 F150 (Ford)
  • loneagle
28 Oct 2020 15:04
#837901
OK Ed, I guess I missed it. Sometimes, I can't see the forest thru the trees! :)
'02 Harley FXDWG
  • loneagle
28 Oct 2020 15:08 - 28 Oct 2020 15:10
#837902
Right now, I'm installing a needle bearing pusher and a new ball bearing. Hopefully, it will make the clutch easier.
'02 Harley FXDWG
Last edit: 28 Oct 2020 15:10 by loneagle.
