header mounting 79 KZ 650 SR 4 into 1
  • xstreamcanadian
  • xstreamcanadian's Avatar Topic Author
26 Oct 2020 11:41 - 26 Oct 2020 11:43
#837756
Im missing something here. Do I not need the split keepers I am assuming with the header? or is there a way this puzzle all goes together. the copper gaskets(new also) are in you just cant see them in the pics. the last one is just the header and the collar used, it seems to be the same as the split keeper and collar depth wise. Im easily confused.
Attachment 122928510_1510821175772425_652787388855469389_n.jpg not found
Attachment 122927323_353594135724886_7682964904834565151_n.jpg not found
Attachment 122892855_355694128866472_6451726650835724904_n.jpg not found
Last edit: 26 Oct 2020 11:43 by xstreamcanadian.
  • loudhvx
  • loudhvx's Avatar
Re: header mounting 79 KZ 650 SR 4 into 1
26 Oct 2020 13:58
#837771
When the aftermarket header has non-removable flanges, like yours do, you are not meant to use the split collars or the factory, finned-flange.
But keep the split collars and flanges as they are valuable and you may need them for some other aftermarket headers which require them.
The following user(s) said Thank You: xstreamcanadian
  • xstreamcanadian
26 Oct 2020 15:27
#837781
Ok thank you sir. Wasnt making sense. I have lots of split collars now as I bought all new ones of course prior to trying to fit this thing in. The flanged ones seem to fit on but ill leave them all to the side. I scratched the hell out of my paint on the frame so I have to go backwards before moving forward now, story of my life. Thanks for the reply
