Oil leak on my 1982
- DadaFrog
Oil leak on my 1982
17 Oct 2020 15:04
I have a 1982 I have a 1982 Kawasaki Kawasaki KZ440
That appears to have a small oil leak at the valve cover gasket or breather cover O-ring I think I found one online but when I looked at the description it said that it was in an OS gasket that would fit my KZ440 And a 900 so I’m just trying to figure out if they happen to have the same breather cover or am I missing something in the wording??
Part description on eBay says:
“The par NOS Genuine Kawasaki Breather O-Ring KZ400 KZ440 ZR900 KZ ZR 400 440 900 LTD ABS t number for the NOS -O-ring IS
(PO.NO.— 92055-1020)”
So will this fit my 1982 kZ440 Valve cover/breather cover gasket/O-ring????
And if not if anyone can leave me in the right direction it would be greatly appreciated!!
, Thank you,
Jim
ALSO::::
For some reason I cannot attach a picture it says that I need to complete the( CAPTCHA ) Which I have no idea how to access it where it is what it means or what I need to do any help on this matter would be greatly appreciated as well!!!!!!
, Thank you,
Jim
ALSO::::
Re: Oil leak on my 1982
18 Oct 2020 14:10
That is the correct part number for the breather cover o-ring. It also fits the fuel evaporative canister on the modern Z900 (not KZ900). I do not know how old that NOS is, but you can still get brand new ones from Kawasaki.
www.partzilla.com/catalog/kawasaki/motor...cylinder-head-covers
18 Oct 2020 14:12 - 18 Oct 2020 14:16Oops. I was going through the process of posting a picture because I could not remember the details of tha captcha, but I did not have to do it. Strange.
At any rate, it is a block of pictures from which you have to pick the ones tha have something in common, like a tree or a person or such. It should appear just below where you were submitting the picture. Be sure to click the Insert button before submitting.
Last edit: 18 Oct 2020 14:16 by TexasKZ.
