Kz550 cylinder head on GPz
  • Curtismty
  • Curtismty's Avatar Topic Author
29 Sep 2020 17:49
#835887
Do any of you know wether or not a 1982 KZ550 cylinder head will fit on a 1982 GPz550 motor? Thanks!
  • Nessism
  • Nessism's Avatar
Re: Kz550 cylinder head on GPz
30 Sep 2020 04:51
#835901
Curtismty wrote: Do any of you know wether or not a 1982 KZ550 cylinder head will fit on a 1982 GPz550 motor? Thanks!
I suspect the head will fit but there will be differences. The KZ has a mechanical tach drive and the GPz uses electronic for example. Hopefully someone more familiar with detail out other differences.
  • loudhvx
  • loudhvx's Avatar
30 Sep 2020 09:04 - 30 Sep 2020 09:10
#835914
Like Ed said, the head will almost certainly bolt on, but the intake ports will be different if you are talking about a Kz550 A or C model. Those use Tk22 carbs.
The 82 gpz (H model) uses larger ports for the larger Tk26 carbs.
The 83 kz550A uses the larger ports, as do the shaft drive models (M and F). So if by chance the kz550 head is from an 83 A model made in 1982, it will have the same ports as the H gpz.
Last edit: 30 Sep 2020 09:10 by loudhvx.
  • Pagala
  • Pagala's Avatar
30 Sep 2020 11:02
#835919
Won't the cams also be different?
1̶9̶8̶3̶ ̶K̶a̶w̶a̶s̶a̶k̶i̶ ̶G̶T̶5̶5̶0̶ ̶(̶U̶K̶-̶o̶n̶l̶y̶ ̶m̶o̶d̶e̶l̶)̶,̶ ̶a̶l̶s̶o̶ ̶k̶n̶o̶w̶n̶ ̶a̶s̶ ̶t̶h̶e̶ ̶Z̶5̶5̶0̶ ̶G̶1̶,̶ ̶r̶e̶g̶i̶s̶t̶e̶r̶e̶d̶ ̶i̶n̶ ̶1̶9̶8̶4̶.̶
1981 Kawasaki Z440 (KZ440C1)
  • loudhvx
  • loudhvx's Avatar
30 Sep 2020 13:12
#835928
Yes, but he can use his old gpz cams.
  • Curtismty
30 Sep 2020 17:41
#835946
Thanks for the answers. I find it odd that Kawasaki made all these little changes within 3 years but I guess they were just trying to make them better.
  • Injected
  • Injected's Avatar
06 Oct 2020 14:38
#836302
If the GPZ750 is anything like the GPZ550 watch out for higher piston domes on the hotter GPZ than the KZ. The GPZ750 head had different combustion chambers to accommodate the higher domed pistons, I don't know if this is true for the 550 motors because I have never owned one. You can use Bondo or Plasticine to make sure you have a minimum of 1mm clearance between the combustion chamber and the piston dome (with head gasket in place)
1978 KZ650B2 modified project
