KZ1000 Police P21 (2002) front sprocket
  • AndreK
  • AndreK's Avatar Topic Author
26 Sep 2020 06:55
#835681
The front sprocket part number is 13144-1318.
However, from my knowledge, this part is not available.
Is there any replacement available?
If not 17 tooth, I can adapt with changing the rear sprocket.
Any help is appreciated.
Thanks.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: KZ1000 Police P21 (2002) front sprocket
26 Sep 2020 12:37 - 26 Sep 2020 12:40
#835694
I think all of the J engines use the same basic front sprocket, the only difference being tooth count. Based on a quick search, it looks like the 17 tooth sprocket was only used on the last few years of the police bikes. Most of the other J engined bikes, including earlier P bikes, seem to have used a 15 tooth sprocket. That one seems pretty easy to get.
www.jtsprockets.com/catalogue/model/s1515/
Here is a list of the 15 tooth bikes.
www.jtsprockets.com/catalogue/part/JTF522/
Last edit: 26 Sep 2020 12:40 by TexasKZ.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
27 Sep 2020 05:48
#835713
Are you using that heavy 630 chain?
Might be a good time to swap over to a 530. I used a 18/42 gear combo.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • TexasKZ
  • TexasKZ's Avatar
  • Away
27 Sep 2020 05:52
#835714
ThatGPzGuy wrote: Are you using that heavy 630 chain?
Indeed, going to a 530 will open up many more choices that include all the modern advances that have been made in drive chains.
  • AndreK
12 Oct 2020 00:26
#836675
By change to model P21 in 2002, chain became 530.
And yes, I have chain pitch 530.
From 17/46 to 18/42 might be a little to long.
Anyway, what 18 tooth sprocket you used please?
  • ThatGPzGuy
12 Oct 2020 05:57
#836683
AndreK wrote: From 17/46 to 18/42 might be a little to long.
I purchased the chain and sprockets from Z1. Give them a shout...
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • TexasKZ
  • TexasKZ's Avatar
  • Away
12 Oct 2020 06:13
#836684
  • ThatGPzGuy
12 Oct 2020 08:10
#836692
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • VTEC
  • VTEC's Avatar
13 Oct 2020 17:53
#836819
Be careful if using an aftermarket front sprocket. Lay it on a table and compare the off-set to the original.
I did this years ago and got a chain whine because the off-set was wrong throwing the chain out of line. A tech at a Kawi dealer said he's seen it many times, and you have to use OEM to keep the chain straight, Got one and never had a problem since.
KZ1000-K2
ZRX1100
XR400R
