Clutch cable length?
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
24 Sep 2020 13:21
#835607
My older buddy that lives across the street has an 82 KZ1100 Spectre that he has recently replaced handlebars with 2" riser bars. Anyone know what he should ask for to get the right length of clutch cable? He says it just looks funny with stock cable and those bars. Think the brake line going to the handle bars needs to be shorter as well.
Thought nobody better to ask than you all.
1982 KZ1100D1
  • H1Vindicator
  • H1Vindicator's Avatar
Re: Clutch cable length?
24 Sep 2020 16:14
#835612
he should measure for a new cable. tell him to pay attention how the old cable is routed. something as simple as replacing cables can be vexing.
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
25 Sep 2020 03:18
#835624
He claims it was 49"
1982 KZ1100D1
  • martin_csr
  • martin_csr's Avatar
25 Sep 2020 05:45
#835627
To avoid getting the wrong cable, he'll need to measure the old one & figure out how long the new one needs to be. Some guys use a homemade measuring device, such as a length of clear tubing. Or if possible, he could disconnect the old clutch cable at the clutch lever, extend the end past the lever until the length looks right, then measure the overage & subtract that from the length of the old cable after measuring it. He should move the handlebars side to side while holding the old cable end firmly in place.
  • havakaw
  • havakaw's Avatar
26 Sep 2020 07:58 - 26 Sep 2020 07:59
#835683
Try a 1982 GPZ 1100 clutch cable. Motion Pro makes one that's a good length. That's what I went with when I put Daytona bars on the 1100A.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Last edit: 26 Sep 2020 07:59 by havakaw.
  • Mikaw
  • Mikaw's Avatar
26 Sep 2020 08:06 - 26 Sep 2020 08:23
#835685
This is for throttle cables but they sell DIY clutch cable kits also
www.bing.com/videos/search?q=motorcycle+...iew=detail&FORM=VIRE
Heres a link to the Clutch cable kit. shop.revivalcycles.com/revival-cycles-si...or-clutch-cable-kit/
Heres another brand. www.venhillusa.com/products/cable-kits-a...arts/cable-kits.html
Last edit: 26 Sep 2020 08:23 by Mikaw.
