Pulley Cover Screws?
- ERIK814
21 Sep 2020 09:29
I stripped one of the screws on my engine pulley cover and figured I'd replace all four since I'm at it: three 6x50 pan head screws and one 6x40 pan head screw (Item # 220B0640 & 220B0650). Does anyone know if I can use M6-1.0 x 50 mm Phillips Pan Head Stainless Steel Machine Screws instead of the OEM screws from Partzilla or similar? They may not be JIS, but they are significantly less expensive and no wait time.
For reference: www.partzilla.com/catalog/kawasaki/motor.../engine-covers-80-d1 (#14 and 15)
Standard machine screw: www.homedepot.com/p/Everbilt-M6-1-0-x-50...rew-843278/204846008
Thank you!!
Thank you!!
1981 KZ 440 LTD Belt Drive (Late Model)
- Bob Maximum
Re: Pulley Cover Screws?
21 Sep 2020 12:59
The thread is the same so I can't see why not, but obviously cut the one shorter screw down by 10mm to 40mm.
1972 Kawasaki F8a bison with 350cc top end.
1975 Kawasaki F9c bighorn 350cc
1978 Kawasaki KZ1000 LTD
1984 Yamaha XT600
2006 Yamaha FJR 1300
1984 Yamaha XT600
21 Sep 2020 14:08
If you are going to use stainless steel, it would be a good idea to use some anti-seize compound on the threads.
- Irish Yobbo
21 Sep 2020 15:53
No reason why these wouldn't work.
Having said this, have you considered moving to hex head bolts? These motorcycles don't even use phillips heads from the factory, they use JIS heads which are very similar to phillips. That's why they're so easy to ruin. Also, phillips heads are designed to cam out at a fairly low torque. This is a historic design choice that prevented over-tightening on assembly lines when everything was done by hand. It's not a good feature if tightening over and over again over the years.
If you use hex head bolts, the heads will never wear out or get damaged from normal use, and you won't need to worry about mixing JIS and phillips heads. I switched to stainless hex heads on my entire engine (you can get kits) and it's been a fantastic mod for a very low price.
1981 KZ750 LTD
- ERIK814
21 Sep 2020 19:58
Thanks for all the feedback. I'm going to try swapping out for some hex bolts and see how they work.
- Kidkawie
- I bleed premix
21 Sep 2020 20:29
The screwdriver in any Japsnese factory toolbag is JIS.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- slmjim+Z1BEBE
22 Sep 2020 06:37
Because common handheld hex tools can often increase leverage, it's easy to over tighten hex head screws & strip aluminum threads. A gentle touch or, ideally, a torque wrench is recommended when using hex screws.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: 650ed, Grcko
- KZB2 650
23 Sep 2020 07:37
Consider allen heads too.......... I replaced mine (all but the valve cover) after a article in Motorcyclist many years ago and have had exc luck with them. They are extra nice when putting on new boots........ but like hex heads just don't over tighten em. I got half from a company they had listed and a few from Ace.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
