Repainted tank now won’t run 1979 kz1000 st
- Diocletian
12 Sep 2020 15:47
Hi there I just painted tank and put it back together.I found the fuel line at the bottom of hose was wired tight and was leaking.After I fixed that the petcock was dripping.I can start the bike it runs with choke on but dies out.I do hear a dinging in the engine.Maybe the spark plug cables out.Any ideas.I just bought a new hobbie
Thanks
Thanks
Voyager xii
Kz 1000 st
Kz 1000 st
- Diocletian
Re: Repainted tank now won’t run 1979 kz1000 st
12 Sep 2020 15:58
Just went and fired it up I smell a lot gas burning too.
Voyager xii
Kz 1000 st
Kz 1000 st
- KZJOE900
- Administrator
Super Users
12 Sep 2020 20:57
Hi Diocletain, from the title from your post, I am assuming that the bike ran properly prior to painting the tank. All I can think of is that there could have been debris in areas of the tank that would have been stirred up from removing and painting the tank. Some debris cold have made it into the carburetors and caused a number of different problems. From leaking petcock to sticking float valve needles to clogged jets. It is also possible that fuel could have found its way into the crank case. Check the oil level and look to see if the oil level has all of a sudden got higher. You can also open the oil cap and smell for gasoline in the crank case. If so, that will need to be rectified and the carburetors worked on to stop any leaking and any blockage.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Diocletian
12 Sep 2020 23:36
Thanks I will take a look at that.
Voyager xii
Kz 1000 st
Kz 1000 st
- Diocletian
14 Sep 2020 18:22
Thanks kzjoe900 you hit it right on the head .I pulled the carb and all 4 jets were plugged up.Cleaned em and fired right up.
Thanks again
Thanks again
Voyager xii
Kz 1000 st
Kz 1000 st
14 Sep 2020 18:41
You should install a good fuel filter between the tank and carbs to catch the other debris that is floating around in the tank. A Golan super mini will do a great job and takes up very little room. Yes, it is more expensive than most, but the filter media is cleanable, so it will likely be the last one you ever buy.
14 Sep 2020 18:42
14 Sep 2020 18:42
14 Sep 2020 18:42 - 14 Sep 2020 18:45
golanproducts.com/shop/
Last edit: 14 Sep 2020 18:45 by TexasKZ.
14 Sep 2020 18:50
Holy @&-:!
I have no idea why there are so many duplicate posts. Hopefully an admin will come along and sort me out.
The following user(s) said Thank You: Diocletian
- Diocletian
18 Sep 2020 19:51
That’s a great idea.I just ordered one.Took bike on a 30 mile excursion on the way back bike started losing power.It would speed up then slow down.Im assuming the carbs are dirty again.Before I bought the bike it sat for 10 years.
Voyager xii
Kz 1000 st
Kz 1000 st
- Highway Magician
18 Sep 2020 21:07
Now is a good time to get ahead of this and run an electrolysis clean-out.
You'll be amazed at what electrolysis will pull out of an old gas tank.
I just ran a clean-out on a GPZ1100 tank which looked incredibly clean inside.
Nope, 5+ gallons of nasty-looking black gunk and rust got pulled out of it.
Fight this issue at the source. The gas tank!
If you try electrolysis, an old manual battery charger works best. Avoid "smart chargers"
because most are looking to "see" battery voltage and won't work if they don't.
There are tons of electrolysis how-to videos on youtube.
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
