KZ1100 dropped 2 cylinders
- Gearhead63
12 Sep 2020 12:09
I have had my KZ1100 running for about 6 months when I noticed some misfiring and now the no 2 & 4 cylinders aren't firing (slightly warm or cold) header pipes. Compression is between 140-150, all cylinders are getting spark (replaced plugs and wires) and I had done a basic rebuild on the carbs awhile ago (replaced boots as well.. I took the carbs off, there is gas in all the bowls and made sure all the jets are clear. What might I be missing? Next on my list is doing a valve adjustment but I don't think valve adjustment is an issue given I have good compression and this problem surfaced in a short amount of time. Thanks for any advice.
1981 KZ 1100A1
1996 ZX6 EV conversion
1975 Fiat X1/9 project
- daveo
Re: KZ1100 dropped 2 cylinders
13 Sep 2020 16:52 - 13 Sep 2020 20:04
You mentioned the jets, but are all the fuel and air passageways clear as well?
My engine is loving a little more fuel in the mix these cooler days. I bumped up to 20 pilots, and am seriously considering 22.5's.
:evil:
:evil:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 13 Sep 2020 20:04 by daveo.
The following user(s) said Thank You: Gearhead63
13 Sep 2020 17:03
I don't know the bike very well. Does it have an exciter to boost the pickup signal?
- Gearhead63
26 Sep 2020 12:26
It has the typical cdi ignition. Getting strong spark again after replacing all plug wires. I disassembled carbs again and made sure everything was clear and no debris at the bottom of the bowls. Did find that the jet plug o-rings were not sealing. I had a set of used rubber plugs leftover from another project and used those to temporarily fix the problem. If my carburetor knowledge serves me correctly, this would have caused a rich conditions and maybe caused fouling?
Took the opportunity to do a bench sync (one of the adjustment screws had come loose and readjust float level (lowered it a bit). Now it works great! Running stronger than ever, pulling smoothly right up to 8500. Still
1981 KZ 1100A1
