wont idle down/oil leak
- Mitch`s KZ
12 Sep 2020 04:47
Hi everyone, I`m having 2 issues. first one happened when I was blipin the throttle repididly. I would let it idle down and then I would twist the throttle as quick as I could. I was trying to see, or I wanted to know if I could get an immediate throttle response. It would spit through the carb and almost stall out if i didnt back of the throttle. After about 8 times of this it started to idle down very slow, and it wouldnt idle down below 2000 rpms. My question is this, is it possibly an advancer spring issue or does the idle screw need adjusted. I`m kind of puzzled why its idling high after blipin the throttle a number of times. I have a dyna ignition installed a month and a half ago with no issues.
My second issue is that there seems to be an oil leak somewhere up by the head where the carbs are. I`m thinking maybe it could be a head gasket. Does anyone have any thoughts of what else it could possibly be. its didnt seem to be a lot of oil but i didnt run it that long either. Thanks Mitch
Mitch
- Warren3200gt
Re: wont idle down/oil leak
12 Sep 2020 05:12
If you open the throttle from idle to full throttle instantly your leaning the mixture as the slide let's in more air before the jets can react to let in more fuel.
You would never open the throttle that quickly when riding so it doesn't occur during normal use.
Oil leak could be cam cover, head gasket or cam chain adjuster depending where the oil is evident.
- Rick H.
12 Sep 2020 05:45
A picture of where your oil leak is may help in diagnosing where it is coming from.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
12 Sep 2020 06:14 - 12 Sep 2020 06:16
As mentioned above, a hanging idle is often the result of a lean mixture. This can be caused by clogged jets, low fuel level in the carburetors, old, hard, leaking carb holders. Yes, a sluggish or stuck mechanical timing advancer can also cause it.
It would be helpful if we knew which year and model KZ you have, as there are significant differences between mechanical carbs and constant velocity carbs, mechanical spark advance and electronic advance, et cetera.
Last edit: 12 Sep 2020 06:16 by TexasKZ.
- ckahleer
12 Sep 2020 07:27
As a general rule, you should not be able to blip the throttle until the engine is fully warmed up. if you can your too rich. Does applying the choke help throttle response?
Its hard to pinpoint an oil leak on an oily engine. I clean the engine good with a de-greaser. Once the engine is dry and clean, start it and watch for leak to develop. Have a flash light and inspection mirror handy. Don't ride the bike. The wind can blow the oil around, making it look like it is leaking in places it isn't.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Mitch`s KZ
- Mitch`s KZ
12 Sep 2020 10:34
thanks good idea about the mirror. the engine is clean so i will try that
Mitch
- Mitch`s KZ
12 Sep 2020 10:35
ill try the choke today and let you know thanks
Mitch
12 Sep 2020 11:38Mitch`s KZ wrote: its a 1977a kz
KZ 200 A? KZ1300A?
- Mitch`s KZ
- Mitch`s KZ
12 Sep 2020 13:28
so I started the bike up again today after 3 days of sitting and the only thing it was doing was idling a little high. So I adjusted the idle down to 1100 rpms and it revved up and settled back down just fine. So i let it run for 10 minutes and no oil leak. Took it for A quick ride and when I parked it no oil leak. Not sure why I noticed a leak the other day but today its fine. I did purchase a mirror to try and see behind the carbs. unfortunately the mirror was a little bit big so I couldnt see everything, but what I did see, there was no noticeable oil leaks. tomorrow I will run it a little bit longer and get a smaller mirror to check with. thanks for the help guys, everyone here is awesome with the help. God Bless Mitch
Mitch
- Mitch`s KZ
12 Sep 2020 13:31
hey Warren is this your collection of kaws.?
Mitch
