- Thank you received: 3
Factory holes in KZ400 block
- Wez
09 Sep 2020 11:51 #834665
by Wez
Factory holes in KZ400 block was created by Wez
- M_a_t_t
- Thank you received: 41
09 Sep 2020 12:27 - 09 Sep 2020 12:28 #834669
by M_a_t_t
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Replied by M_a_t_t on topic Factory holes in KZ400 block
Your first 2 pics aren't showing up.
Do the top 3 holes go through?
If I had to guess it would be locating pins for a machining operation. Just a guess though. I've never messed with the smaller KZ's
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
Last edit: 09 Sep 2020 12:28 by M_a_t_t.
- Thank you received: 1847
09 Sep 2020 12:33 #834671
by Mikaw
Replied by Mikaw on topic Factory holes in KZ400 block
My big fours have the larger hole in a similar location. I’d say it’s to drain off water or fluids the would collect on the top of the transmission case. Not sure about the 3 smaller
- loudhvx
- Thank you received: 1615
09 Sep 2020 13:03 - 09 Sep 2020 18:25 #834673
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Factory holes in KZ400 block
Like Mikaw said, the large one allows water or gas to drain into the chain sprocket area and out onto the ground from there.
The smaller ones are bores for threaded holes on the other side. They hold bolts inserted from the other side. The one to the far right may also hold a hollow guide dowel on the other side as well (shown here in the left red circle).
1981 KZ550 D1 gpz.
Other links.
Last edit: 09 Sep 2020 18:25 by loudhvx.
- Wez
10 Sep 2020 12:07 #834756
by Wez
Replied by Wez on topic Factory holes in KZ400 block
Thank you gentlemen!
