Need to find replacement for right side crankshaft seal
  • WildbucksVP
  • WildbucksVP's Avatar Topic Author
27 Aug 2020 22:56
#833827
undefined I bought a 1981 kz440A2 a couple weeks ago. Got it very cheap because it had a stuck piston, the guy that had it before the guy I bought it from was very dumb and pulled one of the plugs to use in another engine and let the bike sit out in the weather. I got it unstuck, honed the cylinder to clear rust and smooth everything out properly and cleaned the carbs out and it fired right up after a little priming and choking. Once it got warm oil started dripping from the transistor points cover, shut it off and pulled the cover off and removed the points/advanced timing mech and the seal is worn out from sitting up forever. Just found out they no longer make the seal and decided to join this forum to see if anyone knows of a compatible one I could get, or if anyone knows if a seal made for the 440 drifter would fit
  • Nessism
  • Nessism's Avatar
Re: Need to find replacement for right side crankshaft seal
28 Aug 2020 05:30
#833838
