Concerning noise from clutch
- UnseenKZ
27 Aug 2020 09:55
Hey!
So I have a strange noise coming from what I think is the clutch. It sounds like a dry Ducati clutch and gets louder when I pull in the clutch lever. But goes way when I shift into 1st. Bike also doesn’t shift past 2nd and the shift lever doesn’t spring back. Here’s a video of the sound
- M_a_t_t
Re: Concerning noise from clutch
27 Aug 2020 10:11
Video isn't showing up. If you are having trouble attaching it you can upload it to youtube and link it here.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
27 Aug 2020 10:53
If the shift lever is not returning, it is likely that the return spring is broken.
Kawasaki's positive neutral finder prevents the selection of any gears besides first and neutral until the motorcycle is moving down the road.
If you have a small four or a twin, you have a primary drive chain that can rattle quite a bit if the carburetors are not properly synchronized.
There could also be something loose in the clutch.
- UnseenKZ
29 Aug 2020 09:19
Remove the clutch cover, check the 5 bolts (#15) of the spring plate are not loosen and don´t scratching on the inside of the clutch cover.
