Big block
- Kawiman80
- On my 2nd KZ1000
Big block
23 Aug 2020 05:29
Its been a long time since I've been on here. Life has happened alot recently. But do have a few questions. who all is running a big block(1500 cc) on the street and is 13.5-1 capable of being turned over by the starter?
This is going to be a street/strip/show bike but want to ride it on occasions .
Thanks
Thanks
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
- DFIGPZ
- Kawiman80
- On my 2nd KZ1000
Re: Big block
23 Aug 2020 10:42
At this point, I'm looking at a GPZ head. The pistons are set up for it. I have one, but done want to invest money if I cant use it. I know its better stock and doesn't need alot of work versus a heavily modified kz head to net the same performance.
- urankjj
Re: Big block
23 Aug 2020 11:55
Sounds like you may have to modify a car starter for that motor
I have an old build that is an APE big block,1327, 10.25-1, but its kick start only. ( Different crank, and the stock alternator wouldn't match up, so left it off). This old thread may help...
kzrider.com/forum/4-electrical/591538-ho...starter-into-gpz1100
