Gear change
- Timbo23
Gear change
22 Aug 2020 08:52
Iam having trouble selecting gear ,is there a only one way the spring goes on the gear change shaft.
Re: Gear change
22 Aug 2020 11:39
Welcome to KZRider
What is your bike ???
Re: Gear change
22 Aug 2020 13:21
What sort of trouble are you having? KZs have a positive neutral finder, so you can't shift gears from 1st to 2nd unless the motorcycle is moving or the rear wheel is spinning.
- Timbo23
Re: Gear change
25 Aug 2020 11:18
Hi iam Tim my Z1 900a4 has a 4coil spring when I put the cover back on the gear shaft won't move did Kawasaki change the engine case and can you get a smaller spring.
- Gruss4544
Re: Gear change
25 Aug 2020 14:53
The early models 73-76 take a 3 wind spring A 77 and on is to thick and will not work.It binds up shift shaft.
Re: Gear change
25 Aug 2020 15:56
As you can see in the fitment chart, that spring was used on a variety of models. Search the web using the whole part number.
www.partzilla.com/product/kawasaki/92083...fa014ff36ceb456210dc
