1982 Kawasaki KZ 550 h1 clutch repair
  • Nathanb
  • Nathanb's Avatar Topic Author
21 Aug 2020 19:40
#833463
Replacing my clutch when I took off the cover I noticed there's a little strip of gasket missing can I add permatex so that little section and close it up that's what I want to do but I don't know if it's should be done. Anybody got any advice? I want to put it back together now.
  • Nathanb
Re: 1982 Kawasaki KZ 550 h1 clutch repair
21 Aug 2020 19:48
#833464
Sorry about the spelling and wording my hands are all greasy. it's like a 2-inch section of the gasket on the inside of the motor I want to put gasket sealer on there because getting up gaskets like pulling teeth anybody know the outcome?
  • gordone
  • gordone's Avatar
21 Aug 2020 21:55
#833468
I have had broken gasket for valve cover and used Three bond gasket with sucess.
Sorry I could not answear your question more direct...
Project:
  • Nessism
  • Nessism's Avatar
22 Aug 2020 08:50
#833486
Nathanb wrote: Sorry about the spelling and wording my hands are all greasy. it's like a 2-inch section of the gasket on the inside of the motor I want to put gasket sealer on there because getting up gaskets like pulling teeth anybody know the outcome?
Where do you live?
  • Nathanb
22 Aug 2020 09:32
#833494
San Francisco Bay area north.
  • loudhvx
  • loudhvx's Avatar
22 Aug 2020 10:22
#833498
I wouldn't use permatex there. It will end up in the oil.
You can get generic gasket material and make a gasket. Autoparts stores usually carry it. It doesn't take long but you have to be pretty careful and precise. A good hole punch will be handy as well.
The following user(s) said Thank You: Nathanb
