Revs
- daveo
Revs
16 Aug 2020 21:37
My 82 elec. tachometer red line is 8500 rpms, and the Dyna 2000 rev limit is set on 9000.
I know she wants it. But I don't know what the limit is, or how long would be considered safe to hold her there.
:huh:
:huh:
1982 KZ1100-A2/1170 sleeper 😀
- zed1015
Re: Revs
17 Aug 2020 00:08
The roller cranks are good to 11000 rpm max before the bearings rollers start to skid instead of roll.
My tuned Z1R has seen 12000 rpm a couple of times in the last 20 years and it's still going strong but i wouldn't recommend that.
If it's still producing power at 9000 rpm then go for it..
- daveo
Re: Revs
17 Aug 2020 06:11 - 17 Aug 2020 06:11zed1015 wrote: The roller cranks are good to 11000 rpm max before the bearings rollers start to skid instead of roll.
:woohoo: K...
:whistle:
Last edit: 17 Aug 2020 06:11 by daveo.
- KZB2 650
Re: Revs
17 Aug 2020 10:46
I've always pushed mine 300 to 500 in the red when things got serious. Have felt safe doing it knowing the KZ engineers have built em tough.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- daveo
Re: Revs
18 Aug 2020 15:03
Had it out for a serious ride today, and tinkered around in the red zone.
We peaked at 9500 and held 9k for many seconds and several times. Didn't mind that, but tells me she wants more... :huh:
I bumped the pilot jets to 17.5 from 15's, and switched 0.7 air jets to 0.8's beforehand.
That was a good move. Whoa!
Oly SH*T!!! Makes me wonder what 20's would be like...
:woohoo: Baby!
:woohoo: Baby!
- daveo
Re: Revs
20 Aug 2020 12:30daveo wrote: Had it out for a serious ride today, and tinkered around in the red zone.
:woohoo: Baby!
Probably not much interest in this subject, but I've discovered the air jets play a significant part in fine-tuning RS Flat Slide carbs. One step off in either direction, and the effect is noticeable and detrimental for smooth engine performance.
I had installed 0.8 as noted, and tried 0.9 thinking both were needed to lean the low end mixture after increasing the pilot jet size to 17.5
Neither size was good, and of the two 0.9 was worse.
So we're back to the 0.7 that I had with the 15 pilot jets, and that subtle change brought a big improvement over the others for smooth engine operation.
Re: Revs
20 Aug 2020 14:41
I think any documented tuning procedures with first hand results are an asset to the members. Maybe not today but someone will benefit. We all want to experience these machines at their full potential.
- daveo
Re: Revs
21 Aug 2020 09:31Mikaw wrote: I think any documented tuning procedures with first hand results are an asset to the members. Maybe not today but someone will benefit. We all want to experience these machines at their full potential.
Can't find much user-friendly info for the RS carbs, considering how long Mikuni has been making them, and how popular they are. :huh:
