- Thank you received: 1
81 kz1100a1 backfiring
- Rossb16a
- loudhvx
- Thank you received: 1616
When that unit fails, it can cause cherry bomb explosions in the exhaust.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Rossb16a
Attachment not found
- Rossb16a
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- DFIGPZ
- Thank you received: 122
1984 750 Turbo
- daveo
- Thank you received: 654
Rossb16a wrote: Turns out I have a twisted crankshaft.
What does that mean, and how do you know that your crankshaft is twisted?
:ohmy:
1982 KZ1100-A2
- Rossb16a
- daveo
Rossb16a wrote: When I did the upper gaskets I noticed that when number one piston was Tdc number four was a quarter inch lower. After tear down it’s quite noticeable that it is twisted. And I had major backfiring when running. Also puffing back through number one carb.
:ohmy: Yikes
1982 KZ1100-A2
- Thank you received: 1918
- loudhvx
1981 KZ550 D1 gpz.
Other links.
