Kz750e Clutch issues?
  • Ricco86
  • Ricco86's Avatar Topic Author
06 Aug 2020 18:09
#832350
I was wondering if someone could give me some advice, my 82 kz 750 once before and now again feels like the clutch seized (somewhat) it had a weird pull on the lever, now it doesn’t happen all the times it went away after I changed the oil this season (new bike to me). I added Lucas motorcycle oil stabilizer today and I got quieter (the engine is a bit noisy) but noticed clutch lever is weird again, but grabs perfectly fine on gears
Ricco
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: Kz750e Clutch issues?
06 Aug 2020 21:04
#832355
Have the cable and lever been properly lubricated?
What do you mean by "feels like the clutch seized?"
Is the motor oil you used approved for motorcycles with a wet clutch?
  • martin_csr
  • martin_csr's Avatar
08 Aug 2020 07:35 - 08 Aug 2020 07:52
#832407
I would do a basic clutch adjustment & adjust the cable. On the 82 750E I believe the clutch release adjusting screw should be turned counterclockwise first until hard to turn, then clockwise 1/4 turn. That's how it's done on a number of 80's models, including my 81 KZ650-CSR >> it's kind of counter-intuitive. Some manuals are ambiguous as to the direction.
Last edit: 08 Aug 2020 07:52 by martin_csr.
