Gas type?
- gordone
Gas type?
04 Aug 2020 13:40
What gas type shall I use, in Europe we have octan 95 and 98?
Project:
Project:
Re: Gas type?
04 Aug 2020 14:09
Super 95 octan fuel is ok, no need to waste your money on Super Plus 98, V Power 100, Ultimate 102 octan fuel.
The following user(s) said Thank You: Mikaw, gordone
Re: Gas type?
04 Aug 2020 20:11 - 04 Aug 2020 20:12
Ok stop... now you even have better fuel then we get in the states... 92 octane is the highest we get. Then you have Unocal 76 and Turbo Blue but they are both 110 octane, and $6 a gallon. Where 92 is $2.60 currently
Last edit: 04 Aug 2020 20:12 by Mikaw.
Re: Gas type?
04 Aug 2020 20:25 - 04 Aug 2020 20:25Mikaw wrote: Ok stop... now you even have better fuel then we get in the states... 92 octane is the highest we get. Then you have Unocal 76 and Turbo Blue but they are both 110 octane, and $6 a gallon. Where 92 is $2.60 currently
In Maryland high test gasoline is 93 octane. All gas stations sell it. Ed
Last edit: 04 Aug 2020 20:25 by 650ed.
Re: Gas type?
04 Aug 2020 20:27650ed wrote:Mikaw wrote: Ok stop... now you even have better fuel then we get in the states... 92 octane is the highest we get. Then you have Unocal 76 and Turbo Blue but they are both 110 octane, and $6 a gallon. Where 92 is $2.60 currently
Ed you might be correct it might be 93 octane
Re: Gas type?
04 Aug 2020 21:04
Europe uses the RON rating method which is higher than the (RON+MON)/2 method used in the USA.
- gordone
Re: Gas type?
04 Aug 2020 22:37Scirocco wrote: Super 95 octan fuel is ok, no need to waste your money on Super Plus 98, V Power 100, Ultimate 102 octan fuel.
Thank you all !
Scirocco, do you fill 98 before as last gas when the season ends, since the 98 don`t contain ethanol?
Project:
Project:
Re: Gas type?
04 Aug 2020 23:58
Super Plus 98 fuel contains 2 - 5 % Ethanol!!! If you need ethanol free fuel you have to fill up your gas tank with Ultimate 102 octan fuel.
I have read in other bike and car forums that Ultimate 102 octan fuel can be stored up tp 3 years without any gasoline stabilizers.
- gordone
Re: Gas type?
05 Aug 2020 00:45Scirocco wrote: Super Plus 98 fuel contains 2 - 5 % Ethanol!!! If you need ethanol free fuel you have to fill up your gas tank with Ultimate 102 octan fuel.
In Norway 98 has not ethanol and 95 has 5% ethanol, there I have thinked about switching to 98...
Project:
Project:
- KZB2 650
Re: Gas type?
06 Aug 2020 05:31 - 06 Aug 2020 06:48
95 Ron = approx 91 oct Ron+Mon/2
98 Ron = just under 94 oct using Ron+Mon/2 and since its ethanol free that would be my choice (mostly for that reason). ( As long as the price is not a big difference).
I have been mixing 93 and 89 for quite a while though as I feel for our compression it might run a tiny bit better.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 06 Aug 2020 06:48 by KZB2 650.
- gd4now
- Denco where did you go?
Re: Gas type?
06 Aug 2020 07:38
Just to all to the conversation this site lists fuel stations that sell non ethanol. Though many have not been updated in some time there are some with very recent comments. Keep in mind I in no way claim any of this is correct or current.
www.pure-gas.org/
www.pure-gas.org/
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- KZB2 650
Re: Gas type?
06 Aug 2020 07:51
2 or 3 stations have worked out for me but they are 40 to 50 miles away. When I was working I'd be with in 12 miles so I stocked up then but gave it up after a couple years.
1978 KZ650 b-2
