Cylinder Bore Diameter Sans the Liner
- Rick H.
01 Aug 2020 13:34
As noted in the title, does anyone know the diameter of the holes that accept the liners in the cylinder block on a '77 KZ-1000A1? I bought a cylinder block without liners and I want to make sure it will properly accept liners, or it goes back to the guy I bought it from. Thanks in advance.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Re: Cylinder Bore Diameter Sans the Liner
01 Aug 2020 14:25
With out any warranty of correctness.
new KZ 900 sleeves (900 - 1015 ccm)
I.D. :65,50mm
O.D. :74,60mm
new KZ 1000 sleeves (1015 - 1045 ccm)
I.D. :69,50mm
O.D. :76,50mm
new Big Bore sleeves (1105 - 1135 ccm)
I.D. :72,50mm
O.D. :78,60mm
I.D. :65,50mm
O.D. :74,60mm
I.D. :69,50mm
O.D. :76,50mm
I.D. :72,50mm
O.D. :78,60mm
The following user(s) said Thank You: Rick H.
