Another set - Identify these Z1 / KZ cam specs
- emy111
30 Jul 2020 06:38 - 30 Jul 2020 06:39Another set of cams.
Apparently they are Engle k-14 and apparently they are .405 lift.
No clue what the duration is.
Anyone have anymore info, or specs on these cams ??
www.kzrider.com/forum/2-engine/502451-en...ms-anyone-using-them
I found that ^^ post above that talks about k-12 and k-13 .... but no mention of k-14 ??
Thoughts?
Thanks.
Last edit: 30 Jul 2020 06:39 by emy111.
- VTEC
Re: Another set - Identify these Z1 / KZ cam specs
Thoughts?
Thanks.
Is there a part number stamped on the ends? Other than that, mount them in a head and break out a dial indicator to determine the specs.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- zed1015
31 Jul 2020 15:23
They look a bit lumpy for 405 lift but may be the pic angles.
I used to run a set a few years back.
Timing specs are 110 lobe centers .
31 Jul 2020 17:11
I got out bid on those by 2seconds and 5$.
:blush:
