Oil leak at shift lever
- Stillridinum
29 Jul 2020 16:29 #831831
by Stillridinum
1982 kz1000 LTD +6” arm from PDM
1980kz440
1998 flsts
Oil leak at shift lever was created by Stillridinum
Hello, 1982 kz1000 LTD, what started as a drip has gotten worse. Going to remove the sprocket cover and the transmission cover, have new seals from Z-1 and a n o s. Transmission cover. Do the new seals press in to the inside of the transmission cover? Anything else I need to be concerned about? Any advice is greatly appreciated!
Thanks
Thanks
1980kz440
1998 flsts
- Stillridinum
04 Aug 2020 18:52 #832245
by Stillridinum
1980kz440
1998 flsts
Replied by Stillridinum on topic Oil leak at shift lever
I got it , thanks for the help
1980kz440
1998 flsts
