What are these for??
- Tmiller
13 Jul 2020 22:58
Hey there everybody, new member here. Recently picked up a neat 1979 kz400 project, some assembly required. I'm having trouble identifying two components, pictured in the post. One is a threaded fitting centered on the front of the heads, I believe it is for the tachometer? If so, I don't intend to use it, can it just be capped off? The other is a post immediately to the right of the starter motor, with a single wire lead coming out if it, and I have no idea what this is supposed to run to. I come from the V-Twin side of things, so any help here would be appreciated!
Re: What are these for??
14 Jul 2020 05:11
I'm not familiar with 400's but I believe you are correct about the tach cable attachment. And yes, it should be blocked off if you don't intend to use a cable tach. The other "thingy" is likely your pressure switch to warn you of low oil pressure. I would not advise to disconnect it.
- Nebr_Rex
14 Jul 2020 05:15
Pics?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
14 Jul 2020 05:46 - 14 Jul 2020 05:47
1979 KZ400-H1 diagrams from Partzilla. If it's a 400B or some other 400 model, they're probably the same.
www.partzilla.com/catalog/kawasaki/motor.../cylinder-head-cover
www.partzilla.com/catalog/kawasaki/motor...9/kz400-h1/crankcase
Last edit: 14 Jul 2020 05:47 by martin_csr.
- gavroyer
14 Jul 2020 17:28 - 14 Jul 2020 17:32
I can confirm that the threaded fitting on the front-left of the head is the tacho drive. The post on the back near the starter is the oil pressure switch, and it definitely needs to be connected. Since you have a 79, there should also be a hard oil line running from that switch up to the head. If that's not in place, the engine should not be run (because that is the top-end oil supply).
1980 KZ440-A1 LTD
Last edit: 14 Jul 2020 17:32 by gavroyer.
