What's fair price for boring & head rebuild?
  • 1981kz750ltd
  • 1981kz750ltd's Avatar Topic Author
04 Jul 2020 07:00
#829743
I'm looking to get the barrels bored and head rebuild on 76 900 engine.
I consulted a mc shop that does in house machine work. I got a quote of $90/hole for boring and $250 the head without new guides. Sounds high to me.
Engine smokes constantly. True milage unknown.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: What's fair price for boring & head rebuild?
04 Jul 2020 07:18
#829745
Those prices are reasonable. Go look into full rebuilds of the KZ1000s etc...
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: 1981kz750ltd
  • Rick H.
  • Rick H.'s Avatar
04 Jul 2020 11:32
#829763
Man I wish my KZ-1000 was that cheap. $600.00 for the head including all guides, seals and exhaust valves with surfacing. $400.00 plus to bore the cylinders. APE did the head on mine so make sure on the quality of the work. $250.00 seems pretty low.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Nessism
  • Nessism's Avatar
  • Mikaw
  • Mikaw's Avatar
04 Jul 2020 17:12
#829804
www.pitstopperformance.com/
Or a member has suggested Raceworks in Canada...
I’m planning a big bore build over this winter...
  • Rick H.
  • Rick H.'s Avatar
05 Jul 2020 06:26
#829825
I have found a good rule of thumb is whatever the estimate is just double it. That way you won't be shocked when you get the final bill.
Rick H.
Rick H.
  • Injected
  • Injected's Avatar
05 Jul 2020 07:08
#829831
Cylinder boring here in Canada starts at $80/hole, the more passes required the price increases. A typical valve job (3-5 angle seat work/plunging) is $240 without guides. Porting varies depending on what you want, typical street porting starts around $400. Now that the dollar is in your favor again its not a bad deal.
1978 KZ650B2 modified project
  • TexasKZ
  • TexasKZ's Avatar
05 Jul 2020 13:44 - 05 Jul 2020 13:47
#829871
At present, $80 Canadian is about $58.40 U.S., which is just a little more than APE charges if you do not buy pistons from them.
($1.00 CDN = $0.73U.S.)
Last edit: 05 Jul 2020 13:47 by TexasKZ.
