Clutch friction plates ?
  • Ronnie_D
  • Ronnie_D's Avatar Topic Author
  • 1978 KZ1000 A2
29 Jun 2020 11:44
#829331
Hello All.
My 1978 KZ1000 A2 clutch is slipping on heavy throttle. I am going to try new springs first. Then, if needed friction plates.
Would any one know the minimum thickness and the new thickness for the friction plates?
your help is appreciated,
Ronnie.
  • Mikaw
  • Mikaw's Avatar
Re: Clutch friction plates ?
29 Jun 2020 11:55
#829336
Have you adjusted the clutch cable back to factory to rule out misadjustments
The following user(s) said Thank You: Ronnie_D
  • Ronnie_D
  • 1978 KZ1000 A2
29 Jun 2020 12:05
#829339
Mikaw wrote: Have you adjusted the clutch cable back to factory to rule out misadjustments
Yes, I am sure it's the springs or the friction plates, probably both.
thanks.
  • Mikaw
  • Mikaw's Avatar
29 Jun 2020 12:20
#829340
I found the information once before for another member hopefully I can find it again... it was listed on the web somewhere that I just need to dig up
  • Mikaw
  • Mikaw's Avatar
29 Jun 2020 12:22
#829341
Partzilla says …
9- friction plates
8- steel
Web search says steel plates are 2.3MM thick.... 8 x 2.3mm = 18.4mm
friction are 2.9 to 3.1 so 9 X 3.0mm = 27mm
18.4mm +27mm = 45.4mm if I'm doing math correct... here in the states we don't use MM as our first form of measurement... and I'm an Old School carpenter...
  • Ronnie_D
  • 1978 KZ1000 A2
29 Jun 2020 12:28
#829343
thank you Mikaw.
I am going to open up the clutch when the gasket and springs arrive.
  • Nessism
  • Nessism's Avatar
  • Mikaw
  • Mikaw's Avatar
29 Jun 2020 14:55
#829365
I yield to Nessism... part number Kawasaki 13088-030 is 3.8MM
  • Ronnie_D
  • 1978 KZ1000 A2
29 Jun 2020 17:59
#829394
Nessism wrote: From the factory service manual...
Thank you Nessism, Mikaw.
and kudos to this fine forum!
29 Jun 2020 20:06
#829405
What oil are you using? Using oil that is not JASO-MA certified can and will make the clutch slip! If you have any questions just ask. Ed
  • Ronnie_D
  • 1978 KZ1000 A2
29 Jun 2020 20:10
#829406
650ed wrote: What oil are you using? Using oil that is not JASO-MA certified can and will make the clutch slip! If you have any questions just ask. Ed
I use Shell Rotella T4
15w40.
29 Jun 2020 20:37
#829407
Thanks. Shell Rotella T4 is JASO-MA certified, so the oil should not contribute to the clutch slippage. Ed
The following user(s) said Thank You: daveo, Ronnie_D
