Clutch adjustment at the lever
- daveo
28 Jun 2020 17:30 - 28 Jun 2020 20:25
Only took me twenty years to try this.
Been riding a few hundred miles with all free play adjusted out of the clutch cable.
Previously, I maintained 3mm +/- free play per FSM, and the lever would constantly vibrate, wiggle and shake while riding.
Now just that tiny amount of lever movement disengages the clutch for smooth-precise shifts, with no slippage under hard acceleration.
It is such a joy to ride...
:woohoo:
:woohoo:
1982 KZ1100-A2/1170 sleeper ๐
Last edit: 28 Jun 2020 20:25 by daveo.
Re: Clutch adjustment at the lever
29 Jun 2020 06:19 - 29 Jun 2020 06:19
Doesn't the free play relieve stress on the inner cable to reduce the chances of the cable end breaking off?
Last edit: 29 Jun 2020 06:19 by martin_csr.
- daveo
29 Jun 2020 09:02 - 29 Jun 2020 09:05
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
The tension is relatively light with the lever resting against the perch stop. The lever seems to activate the clutch more smoothly adjusted this way, though the reach is further from the grip.
Am considering elbow shaped levers to shorten the reach:
martin_csr wrote: Doesn't the free play relieve stress on the inner cable to reduce the chances of the cable end breaking off?
Last edit: 29 Jun 2020 09:05 by daveo.
The following user(s) said Thank You: martin_csr
29 Jun 2020 09:09
No eBay APP ID and/or Cert ID defined in Kunena configurationHereโs a set...
- daveo
29 Jun 2020 09:22Mikaw wrote: Hereโs a set...
The brake lever end has to be identical where it fits the master cylinder housing...
- zed1015
29 Jun 2020 09:23 - 29 Jun 2020 09:24The cold free play of a cable clutch is mainly to allow for heat expansion of the clutch push rod etcmartin_csr wrote: Doesn't the free play relieve stress on the inner cable to reduce the chances of the cable end breaking off?
If set too tight the expanding rod and other components can result in zero or negative clearance causing clutch slip.
Last edit: 29 Jun 2020 09:24 by zed1015.
The following user(s) said Thank You: martin_csr, daveo
- daveo
29 Jun 2020 09:33zed1015 wrote:The cold free play is to allow for heat expansion of the clutch push rod etcmartin_csr wrote: Doesn't the free play relieve stress on the inner cable to reduce the chances of the cable end breaking off?
The noted engagement can be felt after the lever is pulled back about a quarter inch while underway. The actual clutch engagement portion of lever movement is a fraction beyond that.
29 Jun 2020 09:57
By zed1015: The cold free play of a cable clutch is mainly to allow for heat expansion of the clutch push rod etc
Thanks. I was thinking the vibrations caused by riding would stress the end of the cable.
- Rick H.
29 Jun 2020 11:45
If the OP has the lever set to where there is just no free play when cold, as the bike heats up the free play will increase. Depending on the make and material the inner and outer cable are made of, this increase could be substantial or not too bad. On my KZ-1000 with new OEM cables the heat expansion is very noticeable and moves the friction point much closer to the grip. When the bike cools off the friction point moves outward.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
