Piston kissed the sparkplug
- Quigleyje
27 Jun 2020 05:00
I was out riding zx550 yesterday missed second bike revved and the piston hit the spark plug. Is this a rebuild now? Can I put a new plug in and ride it?
81/84 kz/zx550
Re: Piston kissed the sparkplug
27 Jun 2020 05:14
You got nothing to loose in trying. Very strange for that to happen though. Either the rod stretched or you have bearing wear/damage. It's far more common for the valves to hit the pistons resulting in them being bent in that situation.
The following user(s) said Thank You: Quigleyje
- Quigleyje
27 Jun 2020 05:20
Maybe it was a valve not sure just know the plug is flat. Maybe it's just time for a rebuild.
81/84 kz/zx550
- bluej58
- Quigleyje
27 Jun 2020 06:51
Yeah they are the stock plugs
81/84 kz/zx550
- ckahleer
27 Jun 2020 07:28
It's hard to believe bearings could be that bad and not making an awful knock. Check compression. Look through the plug hole at the piston half way up. Can you see damage? Turn engine a little CW then CCW. Is there slop in piston movement.If not,put in a new plug and and rev it again.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Quigleyje
27 Jun 2020 07:38
Yeah there was no noise at all always ran smooth. But it revved past redline. I accelerated pretty hard before missing second. I imagine something is damaged the plug was hit hard.
81/84 kz/zx550
27 Jun 2020 07:42
Did the spark plug have the washer on it? Ed
- Quigleyje
27 Jun 2020 07:45
Yes the washer was on. Maybe over tightened not sure.
81/84 kz/zx550
- Quigleyje
27 Jun 2020 08:31
So I looked in all cylinders #4 is the only one with damaged spark plug. The valve I can see seems to have no damage. No metal picked up with a magnet. Put new plug and I'm getting backfire through that carb. I can only guess bent valve. It still revs fine and no noticable noise.( But it was only for a couple seconds).
81/84 kz/zx550
