400ltd back from the dead
  • petestain
  • petestain's Avatar Topic Author
12 Jun 2020 20:25
#828029
New to the forum. I'm helping my neighbor get his '79 KZ400LTD back from the dead. It has been dead for over a year. He said his lights got really bright just before everything died on him and he couldn't get it started again. I found it had no spark and replaced the coil, plugs, plug caps, points, and condenser. I gapped the points and set the timing per the clymer manual. I also replaced the regulator/rectifier because I suspect that caused the bright lights thing and blew his ignition circuit.
Now it has good spark but it still won't start. I pulled the carbs and cleaned them and blew them out. They're back on and still no luck starting. Checked compression and found both cylinders at ~150. With full choke I get a little bit of rumble like it wants to start but never get it to catch.
At this point I'm stuck and thinking about revisiting the carbs. Any ideas on what I might be missing?
  • petestain
Re: 400ltd back from the dead
18 Jun 2020 23:34
#828433
Bump. Anybody have any ideas?
  • Nebr_Rex
  • Nebr_Rex's Avatar
19 Jun 2020 04:28
#828441
Set your petcock on prime.
If that doesn't work you didn't clean your carbs well enough.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • JR
  • JR's Avatar
19 Jun 2020 13:37
#828479
Starter fluid and if bike has electric start then jump it from a car - NOT RUNNING - battery
