Engine Noise While Running 82 KZ750e
  • Mr_Blonde
  • Mr_Blonde's Avatar Topic Author
06 Jun 2020 22:16
#827505
I finally was able to get my project bike started and running after a lot of carb cleaner, starting fluid, and a new solenoid. It hasn't run in 2.5 years (before I got it). Amid throttling to keep the rpms up (or else it would die) I hear a pop/bang and then it started making the noise in the videos. Best I can tell its coming from the front of the engine, when the inner most right side exhaust port is, also looking at the video it looks like there's smoke coming from the junction there (maybe a leak?).
Was hoping somebody on here would have a better idea as to what may be going on. Thanks in advance.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Engine Noise While Running 82 KZ750e
07 Jun 2020 00:04
#827506
Sounds like some header gaskets are leaking and need to be renew.
  • hardrockminer
  • hardrockminer's Avatar
07 Jun 2020 05:06
#827508
Check the exhaust clamps. It sounds like one is loose.
