Marshall gaskets any good??
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
26 May 2020 15:24
#826586
Marshall Base Gasket VBG4016 '81-'83 KZ1100 (GAK1)
.....this was on EBay, and I can't help but wonder what does the GAK1 mean? Please holla
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
Re: Marshall gaskets any good??
26 May 2020 16:19
#826592
OEM is the safe bet. Well worth the cost. Cheap gaskets will often fail and force you to do the job twice.
The following user(s) said Thank You: urankjj
  • TexasKZ
  • TexasKZ's Avatar
31 May 2020 06:41 - 31 May 2020 06:42
#826997
I initially thought that GAK1 might be models, but I do not remember there being an 1100G, and that gasket would also fit the J,M, P, and a host of others.
I would pass.
Maybe GAK1 is the sound buyer makes when that gasket begins to ooze out from under the block the first time it gets warm........
Last edit: 31 May 2020 06:42 by TexasKZ.
