1982 KZ750 LTD 4Cyl Starter Clutch Failing
- Shmizzle89
17 May 2020 14:16
Hey guys, sorry if there is already another thread (I couldn't find one)
I have an 82 kz750H (11,500 miles) that I'm getting jetted. Upon further looking, I realized my starter clutch is going bad. I knew something was going bad but hadn't had a chance to look at it too much. It still starts and runs, however sometimes it takes 6-7 times to start it and makes a duck sound when trying to start. So i guess my 2 questions are:
1: Is a whole clutch needed or would the rebuild kit with the roller bearings, caps, and springs be what I need?
2: If its best to replace the whole starter clutch, I'm not sure where to find one. I've been searching for a couple days and haven't found one.
Of course ideally It would be better to just replace the whole thing with a new one, however that doesn't seem likely as I can't find it and cost is a slight issue. Any help would be much appreciated. Thanks in advance!
Re: 1982 KZ750 LTD 4Cyl Starter Clutch Failing
17 May 2020 16:43
Yes, there is another thread on this...your other one. You cross posted. You have two posts at KZR now...and both are identical.
- Shmizzle89
17 May 2020 17:03
Haha thanks, I didn't pay attention to it having to be approved before its posted.
