Fudge!!!
  • M_a_t_t
  • M_a_t_t's Avatar
Re: Fudge!!!
13 May 2020 09:31
#825629
Kofla wrote: You can purchase a cheap borescope at Autozone, Home Depot, Wlamart, Amazon, etc. Some borescope cameras can be used attached to a smartphone.
You can rent the borescope at Autozone. The deposit is like $130 or something, but you get it all back when you return it.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • Rick H.
  • Rick H.'s Avatar
Re: Fudge!!!
13 May 2020 13:30
#825642
Typically speaking the resolution isn't so hot on cheap bore scopes, but you should be able to see a bolt I would think. Also make sure the lens will get in your spark plug hole.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • bluej58
  • bluej58's Avatar
Re: Fudge!!!
13 May 2020 15:20
#825653
That's cheap, to bad the seller 97.4 rating :(
78 KZ1000 A2A
