STP oil filter now made by Fram
- loudhvx
09 May 2020 09:27
In case anyone is interested...
The older STP SMO-12 was a re-badged Purolator ML16812. I;ve used these for decades without problems.
The newer STP S6012 is now a re-badged Fram CH6012-01.
All of the above are now made in China.
I'm still going to use it, since I don't think there is a chance of getting non-Chinese filters conveniently anymore.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- gordone
Re: STP oil filter now made by Fram
09 May 2020 10:53
Project:
Project:
- bluej58
09 May 2020 17:14 - 09 May 2020 17:19
I like the Hi Flo's, made in Thailand
I'll use a Fram every 3 or 4 changes when I need to replace the O-rings because they come with it.
78 KZ1000 A2A
Last edit: 09 May 2020 17:19 by bluej58.
09 May 2020 18:55 - 09 May 2020 19:09
By loudhvx: ...
Emgo filters aren't made in Taiwan or Thailand any more? or any other place outside china? I've been using Emgos for a number of years, and the last one I changed was from Thailand, but I haven't checked the other 2 I have.
I bought a lot of 12 Fram CH6012 oil filters off of EB last year & they're made in India. The Emgos have a metal clip where the pleats meet, but not the Frams. I plan on cutting open one of the Fram filters after I get a chance to use one >> I'm particularly interested in how good they're secured to the end caps. I've seen some dissections of Fram car filters >> their construction was horrifying.
Last edit: 09 May 2020 19:09 by martin_csr.
The following user(s) said Thank You: loudhvx, 650ed
09 May 2020 19:13martin_csr wrote: ...................I've been using Emgos exclusively for a number of years, and the last one I changed was from Thailand, but I haven't checked the other 2 I have.
................. The Emgos have a metal clip where the pleats meet, but not the Frams. I plan on cutting open one of the Fram filters after I get a chance to use one >> I'm particularly interested in how good they're secured to the end caps. I've seen some dissections of Fram car filters >> their construction was horrifying.
In the past the K&N oil filters were also made in Thailand and were made quite well; they too had the metal clips where the pleats meet, the filters were all the exact same size, and they had a lot of filter material. However, the last K&N filters I bought were made in China. They had fewer (as in much less) filter material, glue instead of metal clips, and they were all different heights by a bit more than 1/8". Obviously the move to China saved K&N money, but as far as I'm concerned it did not help K&N's reputation at all. I was very disappointed in the Chinese made filters. BTW, I sent a very polite question about the Chinese quality to K&N, but of course they did not respond. Ed
- loudhvx
09 May 2020 21:56
I was only speaking of the filters I can find at auto parts stores near me. Next year I may have to buy online.
1981 KZ550 D1 gpz.
Other links.
Other links.
10 May 2020 06:03
At the most recent oil change, I used a NAPA gold filter. I only casually looked at it, but my impression was that it is as good as, or better than the others I have tried.
- riturbo
10 May 2020 06:10
I always use oem kawasaki filters . Have no idea where they are made . Get them at my local dealer .They always have them in stock as they fit multiple models .Last thing to cheap out on is the filter .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- gordone
10 May 2020 07:49
How do you know if a filter is good or bad?
Project:
Project:
10 May 2020 13:26 - 10 May 2020 13:27
I have an email question into Partzilla to find out who makes Kawasaki filters. Unfortunately they aren't answering questions during the covid crisis.
I want to use filters made in NA or Japan.
Last edit: 10 May 2020 13:27 by hardrockminer.
- bluej58
10 May 2020 14:00
If you want NA you may have to make it yourself
78 KZ1000 A2A
10 May 2020 20:20
I have a Kawasaki oil filter for my KLR. It says it's made in Japan.
