STP oil filter now made by Fram
  • loudhvx
  • loudhvx's Avatar Topic Author
09 May 2020 09:27
#825310
In case anyone is interested...
The older STP SMO-12 was a re-badged Purolator ML16812. I;ve used these for decades without problems.
The newer STP S6012 is now a re-badged Fram CH6012-01.
All of the above are now made in China.
I'm still going to use it, since I don't think there is a chance of getting non-Chinese filters conveniently anymore.
  • gordone
  • gordone's Avatar
Re: STP oil filter now made by Fram
09 May 2020 10:53
#825313
Project:
  • bluej58
  • bluej58's Avatar
09 May 2020 17:14 - 09 May 2020 17:19
#825347
I like the Hi Flo's, made in Thailand
I'll use a Fram every 3 or 4 changes when I need to replace the O-rings because they come with it.
78 KZ1000 A2A
Last edit: 09 May 2020 17:19 by bluej58.
  • martin_csr
  • martin_csr's Avatar
09 May 2020 18:55 - 09 May 2020 19:09
#825353
By loudhvx: ...
Emgo filters aren't made in Taiwan or Thailand any more? or any other place outside china? I've been using Emgos for a number of years, and the last one I changed was from Thailand, but I haven't checked the other 2 I have.
I bought a lot of 12 Fram CH6012 oil filters off of EB last year & they're made in India. The Emgos have a metal clip where the pleats meet, but not the Frams. I plan on cutting open one of the Fram filters after I get a chance to use one >> I'm particularly interested in how good they're secured to the end caps. I've seen some dissections of Fram car filters >> their construction was horrifying.
Last edit: 09 May 2020 19:09 by martin_csr.
The following user(s) said Thank You: loudhvx, 650ed
09 May 2020 19:13
#825354
martin_csr wrote: ...................I've been using Emgos exclusively for a number of years, and the last one I changed was from Thailand, but I haven't checked the other 2 I have.
................. The Emgos have a metal clip where the pleats meet, but not the Frams. I plan on cutting open one of the Fram filters after I get a chance to use one >> I'm particularly interested in how good they're secured to the end caps. I've seen some dissections of Fram car filters >> their construction was horrifying.
In the past the K&N oil filters were also made in Thailand and were made quite well; they too had the metal clips where the pleats meet, the filters were all the exact same size, and they had a lot of filter material. However, the last K&N filters I bought were made in China. They had fewer (as in much less) filter material, glue instead of metal clips, and they were all different heights by a bit more than 1/8". Obviously the move to China saved K&N money, but as far as I'm concerned it did not help K&N's reputation at all. I was very disappointed in the Chinese made filters. BTW, I sent a very polite question about the Chinese quality to K&N, but of course they did not respond. Ed
  • loudhvx
09 May 2020 21:56
#825360
I was only speaking of the filters I can find at auto parts stores near me. Next year I may have to buy online.
  • TexasKZ
  • TexasKZ's Avatar
10 May 2020 06:03
#825368
At the most recent oil change, I used a NAPA gold filter. I only casually looked at it, but my impression was that it is as good as, or better than the others I have tried.
  • riturbo
  • riturbo's Avatar
10 May 2020 06:10
#825369
I always use oem kawasaki filters . Have no idea where they are made . Get them at my local dealer .They always have them in stock as they fit multiple models .Last thing to cheap out on is the filter .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • gordone
  • gordone's Avatar
10 May 2020 07:49
#825375
How do you know if a filter is good or bad?
Project:
  • hardrockminer
  • hardrockminer's Avatar
10 May 2020 13:26 - 10 May 2020 13:27
#825397
I have an email question into Partzilla to find out who makes Kawasaki filters. Unfortunately they aren't answering questions during the covid crisis.
I want to use filters made in NA or Japan.
Last edit: 10 May 2020 13:27 by hardrockminer.
  • bluej58
  • bluej58's Avatar
10 May 2020 14:00
#825401
If you want NA you may have to make it yourself
78 KZ1000 A2A
  • hardrockminer
10 May 2020 20:20
#825423
I have a Kawasaki oil filter for my KLR. It says it's made in Japan.
