Z500 primary chain
- Rado74
Z500 primary chain
09 May 2020 06:44
Hi. solving problem with primary chain on z500. engine started after irregular operation. carburetors will certainly be to blame. an unpleasant knock came out of the engine. the primary chain has a clearance of 25-26 mm. I can't get a chain. does anyone know the catalog number or from which motorcycles does it fit? thanks
Re: Z500 primary chain
09 May 2020 06:53
If the Z500 used the same chain as the KZ550, it is still available new. Here is a link showing the part number, price, and a fitment chart. The chain can be ordered from Partzilla.
www.partzilla.com/product/kawasaki/92057...5c2657d4c9a11f31744d
The following user(s) said Thank You: Rado74
- Rado74
09 May 2020 07:10
I looked at that primary chain. but the z500 is not there. according to the part number, I did not find a single link on the Internet where the kawasaki z500 or kz500 would be listed.
- Rado74
09 May 2020 07:22
service manual for kawasaki kz500 is simultaneously suitable for kz550 and zx550. if I proceed from this fact, it should fit the kz550. if not I will pay for the mistake.
09 May 2020 07:35
]From what I have read, only only difference between the two is the piston size, unless you are talking about the 500 twin cylinder.
- Rado74
09 May 2020 07:41
z500b, engine kz500 1979, 4 cylinders, great, it helped me, I order kz550
- linuxrob
23 Nov 2021 12:20
sorry for later reply
25mm is worse play on pri chain
part no
92057-1011
part no
92057-1011
1980 Z500 B2 owned from new 78260 miles
1980 Z500 B2 in bits since 1982 23000 miles
2004 GSF1200S Bandit K4
2000 GS125 ESD
2000 GS125 ESD
