KZ1000, can't shift from 1st to Neutral
  • shrap66
  • shrap66's Avatar Topic Author
08 May 2020 05:34
#825224
I searched the forum trying to find something about this.
The bike is a 1979 KZ1000 LTD with a MKII stock engine. The bike runs great. I am able to shift through all the speeds easily. No unusual noises.
When cold when I come to a stop, I am able to go from 1st to Neutral while waiting on a red light.
After running the bike for a while, I can't get it to shift from 1st to Neutral if the bike is still running. If I turn the run switch off, I am able to shift from 1st to Neutral again very easily.
Makes me think it has something to do with a switch ?
Ever seen that before ?
Thanks.
1979 KZ1000B3 LTD Glacier Green
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ1000, can't shift from 1st to Neutral
08 May 2020 06:42
#825231
Clutch drag?
  • kevski
  • kevski's Avatar
08 May 2020 06:43 - 08 May 2020 06:44
#825232
Sounds like clutch needs adjustment.
Last edit: 08 May 2020 06:44 by kevski.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
09 May 2020 08:03 - 09 May 2020 08:11
#825302
Both clutch release action & lever free play change some with heat.
Adjust the clutch at the release mechanism at the countershaft cover and the handlebar lever free play according to Mama Kaw's service manual. Do it with the motor hot, and don't stress about changes in free play when cold.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 09 May 2020 08:11 by slmjim+Z1BEBE.
