It this normal sound from kz550 ltd?
- Lithuania
- Hello from lithuania
08 May 2020 02:46
Hi im new about kz 550 what problem can be in my kz 550 ltd. ? 50.000 km 1982
Carlos kz 550 klt
- loudhvx
Re: It this normal sound from kz550 ltd?
08 May 2020 10:12
Without the airbox connected it will need rejetting to run properly.
To make sure all cylinders are firing at idle, you can spray a little water on the header pipes from a small spray bottle.
To me it sounds out of sync and maybe one cylinder not firing at idle.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
08 May 2020 17:16
With no airbox is will run poorly. Install the airbox with filter - then see how it runs. Ed
