Clutch possibly
- Stoeger1
Clutch possibly
04 May 2020 20:51
just purchased a 1980 kz 750 twin and have been working on it for about a week, i got the starter clutch in order, blew out the carbs and the bike runs like a top. I hoped on to take my first ride on the bike kicked it into first and felt a solid engagement however the bike did not moved. The neutral light turned off however the bike is able to roll as it would if it was in neutral. I order new clutch plate but i was wondering if anyone has had a similar experience, any advice helps.
Thanks
Thanks
- CCrosswait
Re: Clutch possibly
05 May 2020 10:37
Is the chain attached?
This might sound like a stupid question but I've run across someone who thought they had a transmission problem but all it was was the chain flew off the bike.
2019 Indian FTR1200S
2018 Triumph Rocket 3
1981 Kawasaki KZ1100A1
1977 Yamaha RD400
1980 Honda Express II
1977 Yamaha RD400
- Stoeger1
Re: Clutch possibly
05 May 2020 10:40
Yes the chain is still on the bike, and i did double check.
Re: Clutch possibly
05 May 2020 10:40 - 05 May 2020 10:45
Yup. Could be that the nut holding the countershaft sprocket on has gone AWOL.
Has the clutch cable been properly adjusted? There is a specific procedure that needs to be followed.
Also, the clutch release mechanism may be installed incorrectly, or it may be completely clogged up with smegma (technical term for chain lube and dirt :laugh: :laugh: :laugh: ).
Last edit: 05 May 2020 10:45 by TexasKZ.
- Stoeger1
- CCrosswait
Re: Clutch possibly
05 May 2020 10:55TexasKZ wrote: Has the clutch cable been properly adjusted?
+1.
Also confirm the clutch plates aren't missing!
1977 Yamaha RD400
1977 Yamaha RD400
- Stoeger1
Re: Clutch possibly
05 May 2020 11:41
I attempted to adjust the clutch as the manual stated but that didn't solve my problem, I will readjust it when i install the new clutch plates the original plates seemed to be pretty burned up. Im just hoping its a simple adjustment issue and not anything worst.
