Bearing
  • Dareniles
  • Dareniles's Avatar Topic Author
Bearing
24 Apr 2020 13:49
#824167
Hi, can anyone tell me what the bearing behind the panel is called? The bike is a KZ750 N1 spectre 1982 and the bearing is rumbling slightly. Thanks
  • martin_csr
  • martin_csr's Avatar
Re: Bearing
24 Apr 2020 14:36 - 24 Apr 2020 17:29
#824172
www.partzilla.com/catalog/kawasaki/motor...n1/front-bevel-gears
Partzilla has a photo of the bearing & from the info on it, the outer Fr bevel gear bearing is a NTN brand 4T 30205.
There's also a shim etc, so you should read the manual to see what needs to be done. I don't know anything about a shaft drive.
If you need a service manual, search EB for KZ750 shaft manual. There's usually a number of them listed, often times cheap.
Last edit: 24 Apr 2020 17:29 by martin_csr.
The following user(s) said Thank You: Nessism, Dareniles
