dyna s - 2-3 timing advancer marks
  • gixxerkidd03
  • gixxerkidd03's Avatar Topic Author
23 Apr 2020 11:49
#824069
im currently installing a dyna ignition system and coils but my timing advancer does not have a mark for the 2-3 fully advanced timing?!? i have set 1-4 already , but 2-3 side just has the "T" mark. how can i indicate the fully advance timing on coil 2-3?? any thing will have, 81 kz750E. i have this question hasn't been beat to death. THANKS!
1981 KZ750e
  • DFIGPZ
  • DFIGPZ's Avatar
Re: dyna s - 2-3 timing advancer marks
23 Apr 2020 12:52
#824081
set 1 and 4 to "T"
set 2 and 3 to " T"
check advance on 1and 4
Done
1984 750 Turbo
  • Mikaw
  • Mikaw's Avatar
23 Apr 2020 12:57
#824082
Are you doing a static adjustment for first start or a dynamic running timing adjustment? They require bifferent procedures
  • Mikaw
  • Mikaw's Avatar
23 Apr 2020 13:15
#824085
Here’s a topic on the same issue on only have “T” mark on 2-3 cylinders
www.kzrider.com/forum/2-engine/599036-kz...s-not-right?start=40
  • gixxerkidd03
23 Apr 2020 15:38
#824099
Sorry I should have been more clear. I am doing The initial static timing for first start with the test light. I’ll have a read thought the thread to see if it gets me there. Thank you
1981 KZ750e
  • Mikaw
  • Mikaw's Avatar
23 Apr 2020 16:49
#824102
SWest had a good recommendation in that other post, measure the 1-4 distance from “T” to “F” and transferre that to your 2-3 side of the advancer. That will get you close enough to fire up but I can’t tell you how to fine tune dynamic timing without accurate 2-3 timing marks.
  • DFIGPZ
  • DFIGPZ's Avatar
24 Apr 2020 12:46
#824157
it does not matter when 1/4 is correct 2/3 is correct as long as both are timed at "F" mark at idle.
1984 750 Turbo
  • Mikaw
  • Mikaw's Avatar
24 Apr 2020 20:32 - 24 Apr 2020 20:34
#824199
With a Dyna s the pick up modules have a 10 deg adjustability on the breaker plate. Both 1-4 and 2-3 need to be adjusted. There is no guarantee the are set correctly when they are mounted to the plate at assembly. The OP said he has no “F” mark on the 2-3 side of the advancer, he has no way to verify timing on 2-3.
Last edit: 24 Apr 2020 20:34 by Mikaw.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Apr 2020 22:45
#824209
It´s possible to set/sync both 1-4 and 2-3 temporary @ T-mark and advance later to F 1-4 position, ( F 2-3 is then set exact 180 degree off now as it should).
  • Mikaw
  • Mikaw's Avatar
24 Apr 2020 23:02
#824211
Scirocco wrote: It´s possible to set/sync both 1-4 and 2-3 temporary @ T-mark and advance later to F 1-4 position, ( F 2-3 is then set exact 180 degree off now as it should).
Good suggestion! Thanks
  • Nessism
  • Nessism's Avatar
25 Apr 2020 06:23
#824224
DFIGPZ wrote: set 1 and 4 to "T"
set 2 and 3 to " T"
Done
This. Keep it simple.
I've never understood why Dyna recommends checking timing at full advance. When installing a Dyna S I've found if the T mark is aligned the F will be also when you hold the advancer full on.
  • loudhvx
  • loudhvx's Avatar
25 Apr 2020 08:09
#824241
Repeating from his other topic on this subject:
There are a few ways to scratch an (F) mark of your own.
The easiest is to just take off your advancer and measure the distance of the (F) mark from T mark on 1-4 and just transfer that to 2-3 and make your own (F) mark. The advancer is hardened so it doesn't scratch real easy, and sharpie marks tend to fade very quickly, so I use a center punch and make a tiny dimple.
You can also look at the timing advance specs and measure the angle using a pointer on the crank etc. if you need it that precise.
