C3 mis-fire
  • Superbike33
  • Superbike33's Avatar Topic Author
C3 mis-fire
22 Apr 2020 10:18
#823933
Can anyone help ? I have a 1979 z650 c3 , us import , it has had replacement Uk carbs fitted ,cleaned and set up , new points ,condensers,coils . My issue is that it struggles to get past 85 mph , it runs really sweet up to there but starts holding back at about 75-80mph . I’ve had around 6 previous z650,s but never experienced this issue , has anyone else had similar issues or any ideas what the problem might be ? Grateful for any help
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: C3 mis-fire
22 Apr 2020 10:41
#823941
Could use some more info. You running stock exhaust and air box? What type of UK carbs are you running, vm24ss or something else? What size main jet are you running?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Superbike33
Re: C3 mis-fire
22 Apr 2020 10:48
#823942
Hi thanks for your reply , I’m running standard pipes and air box , new filter , not sure what jets are in tho , kept the ones which came with the carbs ?? Standard Mikuni carbs from what I can tell . Came off a B1 possibly ??
  • TexasKZ
  • TexasKZ's Avatar
Re: C3 mis-fire
22 Apr 2020 16:38
#823992
Could the ignition advancer be stuck?
The following user(s) said Thank You: Superbike33
