Spark Plugs Wires.
- Jpallison1722
Spark Plugs Wires.
18 Apr 2020 05:14
Hey guys, first post here. I recently bought an 83 kz650 H3 and was wondering if there is a part number associated with the spark plug wires or do I have to get universal wires and cut them to length and put the connectors on. I can see arcing between the boot and the cooling fin on one and will get shocked if i touch the other ones. Any help would be very appreciated.
Thanks!
Thanks!
Re: Spark Plugs Wires.
18 Apr 2020 05:40 - 18 Apr 2020 05:44
You can use bulk spark plug wire. probably 7mm copper core type. If you still have the stock wires, you can remove the outer sheathing & put it on the new wires (I think Nessism did this). use silicone spray as a lubricant. When I installed new Dyna coils, I went ahead & installed the Dyna spark plug wire set from Z1Enterprises.com, since they included the spark plug caps. This was the easy thing to do. hee.
Last edit: 18 Apr 2020 05:44 by martin_csr.
18 Apr 2020 05:58
The cap's should be replaced too, or at least check the resistance. Z1 Enterprises sells both the wire and NGK caps for good prices.
